https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Parallel input and Serial output (PISO) of USB tranceiver https://designers-guide.org/forum/YaBB.pl?num=1258029179 Message started by somisetty on Nov 12th, 2009, 4:32am |
Title: Parallel input and Serial output (PISO) of USB tranceiver Post by somisetty on Nov 12th, 2009, 4:32am Hi all, Can any one help me regarding VerilogA code for PISO block which is shown in below diagram? Thanks inadvance |
Title: Re: Parallel input and Serial output (PISO) of USB tranceiver Post by Riad KACED on Nov 12th, 2009, 2:47pm http://www.designers-guide.org/Books/dg-vams/index.html |
Title: Re: Parallel input and Serial output (PISO) of USB tranceiver Post by somisetty on Nov 12th, 2009, 9:20pm Thank you very much |
Title: Re: Parallel input and Serial output (PISO) of USB tranceiver Post by somisetty on Nov 15th, 2009, 8:20pm Hi KACED, I could not able find verilogA code of Parallel input and serial output (PISO) under what you have mentioned. (http://www.designers-guide.org/Books/dg-vams/index.html). Please give me some more information on that. thanks |
Title: Re: Parallel input and Serial output (PISO) of USB tranceiver Post by Riad KACED on Nov 16th, 2009, 12:38am Hi Somisetty, I have never said there was any. What I meant is given the few Verilog-A/verilog-AMS you have asked in this forum, you better take a look at the Book I have mentioned. In other words, you better taked a week or 2 of your time, studying verilog-A and Verilog-ams languages. Once it is all clear in your mind, then you may start looking at the hundreds of examples in this forum. You wouldn't expect people to write a tailored model for your very specific need, would you ? Well, if you can't afford buying the book, which is fair enough, then You can look at either the Cadence's Manuals (I posted the links in a previous post) or the Accela LRMs. I can send the links if needed. Regards, Riad. |
