Design >> Analog Design >> PFD  characteristics
https://designers-guide.org/forum/YaBB.pl?num=1259664998
Message started by ReadWDX on Dec 1st, 2009, 2:56am
Title: PFD  characteristics
Post by ReadWDX on Dec 1st, 2009, 2:56am
hi,all
  now I want to design a RF PLL, when I design PFD, I do not know how to simulate PFD characteristical curve,some has done it? I need help, thanks!
Title: Re: PFD �characteristics
Post by Mayank on Dec 1st, 2009, 3:56am
Hello RDX,   :P
                 On a standalone basis, you can simulate your PFD so that the UP & the DNbar or UPbar & DN signals math exactly....ie transition at vdd/2.
The Best way to characterize Phase-detector ckt of a PLL is to plug the PFD and Charge-Pump together.
1. Give two signals on input freq and fed-back Freq with a certain difference in Time-period & that difference as the delay between the clocks transitions. ---> The idea is to basically produce transitions with decreasing/ increasing difference b/w ref. freq node & PLL fed-back node.
2.  Now measure the CPUMP current corresponding to each commparison. You will get a staircase kind of response...
3.  This will help you estimate the gain of your P-D ckt as well as Static Phase Error.
4.  If you want to obtain the gain plot of PD ckt, vary the delay b/w the two clocks at ref & PLL fed-back node and measure the Cpump current o/p.  Plot cpump current o/p against the phase error (360deg * delay / Tcomparison) -- you will obtain a KPD plot as shown in books...My belief is that you however generally dont need that plot.
thanx
mayank.
Post by ReadWDX on Dec 1st, 2009, 11:05pm
thanks Mayank very much
I have done as you suggest,I got the result is followed:
in the plot ,Iout is average of the Charge pump output cuurent,
If you can tell me the problem in my result,I would be grateful!
[img][/img]
Title: Re: PFD  characteristics
Post by raja.cedt on Dec 2nd, 2009, 12:05am
hi,
   seems like your circuit is correct but may be you have given wrong sweep statement. by the what's your Icp? is it 180uA
Thanks,
Rajasekhar.
Post by Mayank on Dec 2nd, 2009, 12:55am
Hello RDX,
                 The shape of the plots seem matching, so i guess your ckt functioanlity is correct....How are you calculating the avg current ??  & What is your X-axis (Delter) and in what units (if phase, degrees/readians) ??
mayank.
Post by raja.cedt on Dec 2nd, 2009, 1:33am
hi,
   i feel sweeping in the -ve direction is wrong and are you finding average over enough cycles.
Thanks,
Rajasekhar.
Post by ReadWDX on Dec 2nd, 2009, 5:53pm
Thanks for all giving  me avaluable advice!
in my design ,I take the charge pump current is 180uA,and the average current is calculated by " average"function in cadence calculator,the "delter" is the delay time of input signals of PFD,unit is secend.
when I calculated the average of current,I took 80 cycles ,Is it enough?
Post by raja.cedt on Dec 2nd, 2009, 7:48pm
hi,
  i feel 80 cycle's are too much.ok any how it's not a problem but have checked abut sweep comand once..i feel there is some problem.
Thanks,
Rajasekhar.
Post by Mayank on Dec 2nd, 2009, 8:56pm
Hi,
    I think the plot is a bit shifted....Ideally the plot should be a piecewise linear plot b/w +pi to --pi on x-axis if your x-axis is in radians. What is your time period 28ns-30ns ??
Can you attach the staircase response of charge-pump o/p voltage node with the i/p & fed-back pulses ?
thanx
mayank
