https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> [Error] Strange char in source text (ASCII (96)) https://designers-guide.org/forum/YaBB.pl?num=1260543655 Message started by michele bergo on Dec 11th, 2009, 7:00am |
Title: [Error] Strange char in source text (ASCII (96)) Post by michele bergo on Dec 11th, 2009, 7:00am compiling a simple verilog ams module with vacom - ams I had the message below: ------------------- 1: `include "disciplines.vams" [Error] Strange char in source text (ASCII (96)) ------------------- 1: `include "disciplines.vams" ^^^^^^^ [Failure] Syntax error : received IDENTIFIER while expecting COMMENT or 'architecture' or 'configuration' or 'entity' or 'library' or 'package' or 'use' Can somebody help me please? bye michele |
Title: Re: [Error] Strange char in source text (ASCII (96)) Post by Geoffrey_Coram on Dec 14th, 2009, 12:59pm This line: or 'architecture' or 'configuration' or 'entity' or 'library' indicates that your compiler thinks the source code is VHDL, not Verilog. You may need to change the extension (.v ?). |
Title: Re: [Error] Strange char in source text (ASCII (96)) Post by michele bergo on Dec 15th, 2009, 4:34am Thank you very much problem solved best regards |
