https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Discrete capacitors for Analog Front End. https://designers-guide.org/forum/YaBB.pl?num=1260981092 Message started by ic_engr on Dec 16th, 2009, 8:31am |
Title: Discrete capacitors for Analog Front End. Post by ic_engr on Dec 16th, 2009, 8:31am Hello All, I am wondering if anyone know if SMD capacitors are now available in smaller than 0201 sizes. My maximum capacitor is 100nF. Currently we get capacitors from pF to 220nF in 0201. I am looking for sizes smaller than 0201 for 100nF capacitance. Thanks ic_engr |
Title: Re: Discrete capacitors for Analog Front End. Post by pancho_hideboo on Dec 16th, 2009, 8:38am ic_engr wrote on Dec 16th, 2009, 8:31am:
Currently "0402(01005)" sizes are available as mass products. See http://www.yuden.co.jp/us/product/goods_top/goods_top1.html |
Title: Re: Discrete capacitors for Analog Front End. Post by ic_engr on Dec 16th, 2009, 8:54am No. I meant 0201. Currently you can get in 0201 capacitors upto 100nF. I am looking for smaller footprint for 100nF and lower capacitors. ic_engr |
Title: Re: Discrete capacitors for Analog Front End. Post by pancho_hideboo on Dec 16th, 2009, 9:03am ic_engr wrote on Dec 16th, 2009, 8:54am:
You mean "Low-Profile" ? ic_engr wrote on Dec 16th, 2009, 8:54am:
I don't know such size. Again see http://www.yuden.co.jp/us/product/goods_top/goods_top1.html Maybe you mean "EIA" code. However I mean "JIS" code. JIS "0603" is equivalent to EIA "0201". JIS "0402" is equivalent to EIA "01005". JIS "0603" is 0.6mm x 0.3mm JIS "0402" is 0.4mm x 0.2mm As mass products, You can get 0.01uF=10nF for JIS "0402" size. You can get 0.47uF=470nF for JIS "0603" size. As engineering sample, you can get 1uF=1000nF for JIS "0603" size. http://www.yuden.co.jp/us/release/pdf/pdf_117.pdf |
Title: Re: Discrete capacitors for Analog Front End. Post by ic_engr on Dec 17th, 2009, 1:32pm Yes I meant EIA code. Does anyone know if we can get EIA code 1005 size capacitors of 68nF at least ? ic_engr |
