https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Passing model file as a string parameter in cadence ocean script https://designers-guide.org/forum/YaBB.pl?num=1261486433 Message started by pkd on Dec 22nd, 2009, 4:53am |
Title: Passing model file as a string parameter in cadence ocean script Post by pkd on Dec 22nd, 2009, 4:53am Hi, I want to do a corner analysis along with several other variable parameters for my design. At present the line specifying the model file looks like this... modelFile( '("/home/pratap/cadence/foundry_data/umc13mmrf/../Models/Spectre/ L130E_HS12_V241.lib.scs" "ss") ) All I need to change is the last argument as "ff" or "tt". So I want to give these strings as parameters from an array and run the simulation. Does anybody have an idea how can I do so? Waiting for some solution, -pkd |
Title: Re: Passing model file as a string parameter in cadence ocean script Post by pancho_hideboo on Dec 22nd, 2009, 5:04am See http://www.designers-guide.org/Forum/YaBB.pl?num=1195191246/3#3 |
Title: Re: Passing model file as a string parameter in cadence ocean script Post by pkd on Dec 22nd, 2009, 3:50pm Thanks! The link helped me get the vital clue. This is how my final code looks like... Code:
Title: Re: Passing model file as a string parameter in cadence ocean script Post by pancho_hideboo on Dec 23rd, 2009, 12:57am "sprintf()" is not required at all for your case. The following works for your purpose. Code:
