https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> noise analysis https://designers-guide.org/forum/YaBB.pl?num=1261998066 Message started by nobody on Dec 28th, 2009, 3:01am |
Title: noise analysis Post by nobody on Dec 28th, 2009, 3:01am Hello, all I have a question about how to do the noise simulation of a "flip-around" SHA in the hold phase. To be more precisely, I question the total output noise @ the hold phase because the magnitude of noise is much larger than expected. If I hook up the circuit like Fig.1 called " charge transferred SHA" ,typically gain= cs/cf=2, the magnitude of output noise looks good. Fig.2 shows the way I did the simulation. An ideal cmfb is added and ideal baluns are used to convert differential and common signals. Thanks a lot. *** spice deck *** vic vic 0 1 vid vid 0 ac .ac dec 100 1e3 100e9 .noise v(vod) vid |
Title: Re: noise analysis Post by Ken Kundert on Dec 28th, 2009, 8:50am Look at http://www.designers-guide.org/Analysis/sc-filters.pdf for an explanation of how to perform noise analysis of a sample and hold amplifier (SHA). -Ken |
