https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Verilog-A with HSPICE https://designers-guide.org/forum/YaBB.pl?num=1262736001 Message started by shary on Jan 5th, 2010, 4:00pm |
Title: Verilog-A with HSPICE Post by shary on Jan 5th, 2010, 4:00pm I'm a new user and am trying to simulate a test resistor.va module with hspice on a linux machine. I've set the environmental variables HSP_HOME and PATH as per instructions in the HSPICE installation guide. However, I still get the error for my first line: `include "disciplines.vams". hsp-vacomp: Error: File not found 'disciplines.vams' in search path '.' Why does it look for the file in search path '.' when the $PATH contains the paths for install and include directories? Is there a special variable or way to set the paths? Thank you. |
Title: Re: Verilog-A with HSPICE Post by patrick on Jan 5th, 2010, 4:12pm Assuming you installed HSPICE in say, /myApps/C-2009.09 then just add export PATH=/myApps/C-2009.09/hspice/bin:$PATH to your path and there should be no need to set HSP_HOME. This was only required on earlier releases, maybe as far back as 2006.03. Patrick |
Title: Re: Verilog-A with HSPICE Post by shary on Jan 6th, 2010, 2:48pm The verilog-a compiler seems to be searching for the file disciplines.vams in search path '.' when compiling the .va code. It is able to find the executables it needs in the <PATH>/hspice/bin after using the export command to update $PATH, but is not able to find include files. The file is located in /myApps/C-2009.09/hspice/linux/veriloga_utils/veriloga/include/disciplines.vams Is there a way to provide this path to search for the include files? Right now it is only searching the current working directory. Thank you. |
Title: Re: Verilog-A with HSPICE Post by patrick on Jan 6th, 2010, 3:48pm What version and platform are you using? |
Title: Re: Verilog-A with HSPICE Post by shary on Jan 8th, 2010, 1:03pm Its Redhat Linux, hspice 2009.09 and verilog-a compiler version is 1.83.100.080509. |
Title: Re: Verilog-A with HSPICE Post by patrick on Jan 8th, 2010, 1:21pm The wrapper scripts in the INSTALL_DIR/bin set HSP_HOME and other variables that the VA compiler uses to find the system include files. If all you do is add this bin dir to your path you should be good to go, for example install dir as: /myApps/C-2009.09 then just add export PATH=/myApps/C-2009.09/hspice/bin:$PATH to your path (I'm assuming bash syntax here). Type, >which hspice it should point to: /myApps/C-2009.09/hspice/bin/hspice does it? Verify that this is the hspice script and not the exe: >file $(which hspice) does this say "C shell script..."? This script sets HSP_HOME and I think a couple other variables. If it's not the script then you're path is set incorrectly. change your path to point to the wrapper scripts. The compiler search path is: .:$HSP_HOME/veriloga_utils/include and since the wrapper in the bin directory sets HSP_HOME it should just work. Hope that helps. Patrick |
Title: Re: Verilog-A with HSPICE Post by shary on Jan 8th, 2010, 2:50pm Hi, Thanks for the detailed response. For my 2009.09 installation, 'which hspice' returned '/myApps/C-2009.09/hspice/linux/hspice' which was an exe, not a shell script. Is this an installation problem? I reverted to my old hspice 2007.12 installation, and that had the hspice shell script in the bin file, which sets the HSP_HOME variable. On using this hspice, I get the error '/myApps/C-2007.12/hspice/linux/veriloga_utils/tools/x86/bin/ld: cannot open crti.o: No such file or directory'. Is that too an installation error? Thank you. |
Title: Re: Verilog-A with HSPICE Post by patrick on Jan 8th, 2010, 3:26pm Is there no directory called: /myApps/C-2009.09/hspice/bin there should be, no? and that's where the wrapper script called 'hspice' exists. Just put that directory in your path and all will be well. Read my previous post. On the compilation issue, if you are on a 64-bit machine running 32-bit hspice then you need to be able to compile 32-bit shared libs. Look for "multilib problem" in the HSPICE manual for details or use hspice64 on this system. |
Title: Re: Verilog-A with HSPICE Post by Geoffrey_Coram on Jan 11th, 2010, 6:17am shary wrote on Jan 8th, 2010, 2:50pm:
I would say so; I just checked my installation of 2009.09, and it finds [whatever]/synopsys/hspice/2009.09/bin/hspice is a shell script. [whatever]/synopsys/hspice/2009.09/linux/hspice is a binary, but this is not the path you should be adding to your $PATH |
