https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> PAC simulation is wrong https://designers-guide.org/forum/YaBB.pl?num=1263507328 Message started by lunren on Jan 14th, 2010, 2:15pm |
Title: PAC simulation is wrong Post by lunren on Jan 14th, 2010, 2:15pm Hi All, I tried to use PSS+PAC simulate a very simple SC circuit (please refer to the attached Picture1). First, the two equal caps are charged to 1.8V and 0.8V, then open the charge switches and then close the middle switch so that the two caps share the chargers and reach the same voltage. Principly, the voltage of sigB increase by 0.5V and the voltage of rstB decreases by 0.5V. The PSS steady state solution is correct (please refer to the attached Picture2). However, the PAC results are not correct (please refer to second picture). The clock is about 4.6Mhz. From PAC, the changes of sigB and rstB are halved (only 0.25V). Picture 3 shows PAC results. Anyone can try this circuit. I was confused by the PAC results. Can anyone give me some hint what was going on? Thanks, Lunren |
Title: Re: PAC simulation is wrong Post by lunren on Jan 14th, 2010, 2:16pm Picture2 (PSS steady state) |
Title: Re: PAC simulation is wrong Post by lunren on Jan 14th, 2010, 2:17pm Picture3 (PAC results) |
Title: Re: PAC simulation is wrong Post by lunren on Jan 14th, 2010, 4:40pm I got the answer. http://www.designers-guide.org/Forum/YaBB.pl?num=1261493675/0#0 |
