https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> PMOS CML Driver optimize? https://designers-guide.org/forum/YaBB.pl?num=1263877553 Message started by DP_Design on Jan 18th, 2010, 9:05pm |
Title: PMOS CML Driver optimize? Post by DP_Design on Jan 18th, 2010, 9:05pm Hi. I'm designing driver of 1.65Gbps TX for display chip. The attached picture is driver of TX. Id=12mA, Rtx=50ohm is given and PMOS input tr size=100u/0.1u , load PMOS tr. size =240u/0.4 is selected in my design of 90n tech. I am do timing simulation with TX driver + 1/2 size same type pre-driver+load condition and check the waveform at Rx, but i am concerned about the simulation coverage. How am i optimize the CML buffer and what should I do for robust design? |
