https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Impedance of a floating current source https://designers-guide.org/forum/YaBB.pl?num=1264068676 Message started by yvkrishna on Jan 21st, 2010, 2:11am |
Title: Impedance of a floating current source Post by yvkrishna on Jan 21st, 2010, 2:11am I am working on classAB amplifier design which uses floating current source to bias the inverter(used as second stage) I have read in couple of books saying that floating curr source will not present any impedance to the signal (proved mathematically also) in the fig shown below it can be proved mathematically that vtest/itest =Rncas (approximately when gmp=gmn) can some one explain how to understand/interpret this result? also what is the impedance of floating curr. source at hi frequencies? regards, yvkrishna |
Title: Re: Impedance of a floating current source Post by yvkrishna on Mar 24th, 2010, 10:57pm any ideas for this ? regards yvkrishna |
