https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Understanding "dB per bin" unit https://designers-guide.org/forum/YaBB.pl?num=1264089636 Message started by neoflash on Jan 21st, 2010, 8:00am |
Title: Understanding "dB per bin" unit Post by neoflash on Jan 21st, 2010, 8:00am In sigma-delta modulator's result showing, I often see units defined as "dB per bin". Sometimes as "dBFs per bin" How to understand this unit? |
Title: Re: Understanding "dB per bin" unit Post by wave on Jan 22nd, 2010, 3:57pm neoflash wrote on Jan 21st, 2010, 8:00am:
FS - Full Scale. Critical as some converters may clip or distort with large signals. http://en.wikipedia.org/wiki/DBFS Bin is usually related to the DFT used to measure the spectral response. How many points taken relates to the width of a Frequency Bin. http://www-inst.eecs.berkeley.edu/~ee247/fa05/lectures/L14_f05.pdf |
Title: Re: Understanding "dB per bin" unit Post by thechopper on Jan 25th, 2010, 5:02pm Since in sigma delta modulators you deal with noise (quantization noise in this particular case) it is necessary to talk about spectral densities rather than spectra. Thus dB/bin is a spectral density unit for the noise processed in the sd modulator, pretty much the same way it is done for "continuous time" noise where the PSD in dB/Hz. In the dB/bin case, you can think of the amount of noise power in each bin, although you cannot tell how it is distributed "inside a bin". That asks for a higher resolution DFT. Best Tosei |
