https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Tools for Mixed-Mode Design Flow https://designers-guide.org/forum/YaBB.pl?num=1264763018 Message started by Pavel on Jan 29th, 2010, 3:03am |
Title: Tools for Mixed-Mode Design Flow Post by Pavel on Jan 29th, 2010, 3:03am Hello, What are necessary packages for Mixed-Mode Design Flow. Am I right saying that one need in 3 packages: 1. IC610 (framework, capture, layout, elaborator, AMS Designer) 2. MMSIM 7.1 (all simulators - Spectre, ncsim, UltraSim) 3. Encounter (placement & routing) Is there somewhere some tool for synthesis (like Synopsys DC Compiler). What is IUS 8.1? Is it replacement for IC610 & MMSIM 7.1. Thanks in advance. Pavel. |
Title: Re: Tools for Mixed-Mode Design Flow Post by sheldon on Jan 29th, 2010, 3:09am Pavel, I think that AMS Designer is in the IUS release stream and uses the MMSIM license. How about VDI for the digital portion of flow? Best Regards, Sheldon |
Title: Re: Tools for Mixed-Mode Design Flow Post by Pavel on Jan 29th, 2010, 3:18am Hello Sheldon, Thank you for answer. So if one has IUS, he doesn't need IC610, ni MMSIM ? What is VDI ? Tool for synthesis ? Best Regards. Pavel. |
Title: Re: Tools for Mixed-Mode Design Flow Post by sheldon on Jan 30th, 2010, 5:27am Pavel, Just to clarify, my assumption was that you were asking for what software you needed to install in order to run the tools listed. In that case, you will also need to install IUS. See the link for information on VDI . http://www.cadence.com/products/di/vdi/pages/default.aspx BTW, why aren't you asking your Sales or support team for this information? Best Regards, Sheldon |
