https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> can anyone recommend me a good NTF function for DSM? https://designers-guide.org/forum/YaBB.pl?num=1265293565 Message started by Lancelot on Feb 4th, 2010, 6:26am |
Title: can anyone recommend me a good NTF function for DSM? Post by Lancelot on Feb 4th, 2010, 6:26am Hi, guys, I hope to design a CT DSM with OSR=8 to reduce the sampling frequency, and the ENOB should be above 12bits. originally, i want to adopt a 4 orders 4 bits architecture, and insert a zero inside the signal BW to improve the SNR. But it's not easy to choose a suitable NTF and the coefficients. can anyone give me some suggestions? |
Title: Re: can anyone recommend me a good NTF function for DSM? Post by Berti on Feb 4th, 2010, 7:49am Unless you know what you do I would recommend to use Richard Schreiers Delta-Sigma Toolbox to design the NTF and transform the result in a continuous-time filter. By the way, I am not so sure whether minimizing the OSR is a good idea, unless it is required due to jitter requirements. By minimizing the OSR of a continuous-time modulator you loose an advantage over discrete-time modulators. Regards |
