https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> gmin in hspice and spectre https://designers-guide.org/forum/YaBB.pl?num=1265665676 Message started by Jin Tang on Feb 8th, 2010, 1:47pm |
Title: gmin in hspice and spectre Post by Jin Tang on Feb 8th, 2010, 1:47pm Hi I have a diode model in both spectre and hspice format. I try to compare the characteristics like dc, cv, et. al. I simulate both models in ICCAP. They are identical models (except the format is different) and i see almost identical behavior in all areas except the low current region where gmin is supposed to be in effect. Spectre shows about 1 order of magnitude lower current. Note that i set dskip=0 for spectre. I set gmin=1e-15 (for spectre) and gmindc=1e-15 (for hspice). Any one has an idea why this is the case? Thanks in advance! Jin |
Title: Re: gmin in hspice and spectre Post by Andrew Beckett on Feb 9th, 2010, 3:34am Maybe it's due to differences in iabstol (I forget the equivalent parameter in hspice). What is the magnitude of the currents that you're seeing? That might allow a more educated guess... Regards, Andrew. |
Title: Re: gmin in hspice and spectre Post by Jin Tang on Feb 9th, 2010, 9:25am The current level i am seeing is about 5e-16 for spectre and 5e-15 for hspice. |
Title: Re: gmin in hspice and spectre Post by Geoffrey_Coram on Feb 9th, 2010, 1:08pm Does the voltage source current equal the diode current? I recall that some simulators don't include the GMIN current as part of the diode current. |
Title: Re: gmin in hspice and spectre Post by Jin Tang on Feb 9th, 2010, 2:22pm I think in my case GMIN current is indeed included, because the current level changes with GMIN. |
Title: Re: gmin in hspice and spectre Post by Andrew Beckett on Feb 10th, 2010, 1:52pm Bear in mind that this is a very small current - and it's almost certainly below the iabstol (unless you've tightened it) in both simulators, and so it's not going to be accurately resolved. Why do you care about the accuracy of a current which is in femtoamps? Regards, Andrew. |
Title: Re: gmin in hspice and spectre Post by Jin Tang on Feb 10th, 2010, 2:03pm My project is to convert a spectre format diode to hspice format. and try to understand any difference. This indeed is a very small current. i think it is pretty much determined by the implementation of Gmin. |
