https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> parallel to serial data in verilogA https://designers-guide.org/forum/YaBB.pl?num=1266254891 Message started by hali on Feb 15th, 2010, 9:28am |
Title: parallel to serial data in verilogA Post by hali on Feb 15th, 2010, 9:28am Can anyone tell me how can i convert my 10bit parallel data chunks into serial 10bit data using Verilog-A ? |
Title: Re: parallel to serial data in verilogA Post by pancho_hideboo on Feb 15th, 2010, 9:30am See http://www.designers-guide.org/Forum/YaBB.pl?num=1260522242/1#1 The followings are general notes for you. - Always describe vendor's name which you use as tool or simulator. - Don't do multiple posts which are same content. - Don't request source code or behavioral model without any efforts. - There are many simulators which have analyses called as PSS, PAC and Pnoise. - Describe in detail with using correct terminologies. - Warnigns are different from Errors. - ADS is not name of simulator. - There is no tool which name is Cadence. - Don't use Direct Plot of Cadence ADE blindly without knowing definition. - All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain. - Don't mix up Simulation with Post Processing. They are completely different phase. - MATLAB are different from Simulink. - Learn measurements using actual instruments. Not "EDA Tool Play |
