https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Cadence Assura Layout https://designers-guide.org/forum/YaBB.pl?num=1266355262 Message started by gabc on Feb 16th, 2010, 1:21pm |
Title: Cadence Assura Layout Post by gabc on Feb 16th, 2010, 1:21pm Hi All, Once I do the DRC/LVS/RCX for the layout of my design. Is there any way in cadence I can just see the parasitics or just the extracted view where parasitics are present? Thanks in advance |
Title: Re: Cadence Assura Layout Post by Andrew Beckett on Feb 17th, 2010, 2:45am This is really in the wrong board - the "Physical Extraction, Verification and Analysis" board would be more appropriate. Probably Ken will move this post when he sees it. Anyway, using Tools->Parasitics (IC5141) or Launch->Parasitics (IC61X) from either the schematic or extracted view will add a "Parasitics" menu. From this you can do things like Report Parasitics (say Net to Net, or for a specific net) and this will list all the parasitics on that net. You can then click on a parasitic and it will take you to where it is in the extracted view. Regards, Andrew. |
Title: Re: Cadence Assura Layout Post by gabc on Feb 17th, 2010, 9:33am Thanks Andrew, and sorry I posted the message on wrong title. |
