https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> foreach command cshell scripting https://designers-guide.org/forum/YaBB.pl?num=1266475402 Message started by avlsi on Feb 17th, 2010, 10:43pm |
Title: foreach command cshell scripting Post by avlsi on Feb 17th, 2010, 10:43pm Hi everyone, In my cshell script, there are few foreach loops in which few commands gets executed. It is written as foreach vds ( 1.1 1.2) foreach temp ( 27.0 126.0) commands ... end end But when i execute the script by sourcing it..There are errors saying foreach: Words not parentisized Please help me to solve the error. Thanks in advance. |
Title: Re: foreach command cshell scripting Post by Ken Kundert on Feb 17th, 2010, 11:51pm What you typed looks okay to me. Use Code:
-Ken |
Title: Re: foreach command cshell scripting Post by avlsi on Feb 18th, 2010, 12:12am Hi Ken, when i put echo in front of foreach loops.The error is Badly Placed ()'s. One more issue in my cshell script is, i have commands like mkdir file1. But the created directory name is file1? . I dont understand why the file is created in this way. Thanks for ur prompt reply. |
Title: Re: foreach command cshell scripting Post by boe on Feb 18th, 2010, 5:07am avlsi, You probably have an invisible control character at the end of your line, e.g. CR (^M, 0x0D). BOE |
Title: Re: foreach command cshell scripting Post by Ken Kundert on Feb 18th, 2010, 12:49pm I was suggesting that you use echo to identify the offending line. Avlsi might be on to something. Perhaps you are using a file formatted for windows or mac on unix, or visaversa. Try opening the file in vi, then type :set ff=unix :wq and try again. Is there some reason why you don't just post the script? It would be much easier to help you if we did not have to guess what you were doing. -Ken |
