https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> awd calculator https://designers-guide.org/forum/YaBB.pl?num=1267198506 Message started by Evgenii on Feb 26th, 2010, 7:35am |
Title: awd calculator Post by Evgenii on Feb 26th, 2010, 7:35am Please help! how to subtract one curve from other curve in awd calculator I tried next "display stack" "wave" -> click on a one curve "minus" "wave" -> click on a second curve, but buttons "evaluate buffer", "plot", "print" doesn't work... >:( ps I need is for evaluating, say, offset voltage Thanks! :) |
Title: Re: awd calculator Post by Andrew Beckett on Feb 28th, 2010, 5:40am If the calculator is in Reverse Polish mode (which is the default), you should do: wave - click on one waveform, then the next Then hit the "-" key Then hit plot. Alternatively you can use the algebraic mode (the choice is in a menu - I can't remember what it's called though, and I'm off line), and use a sequence similar to that you gave. One thing to be aware of is that it is a true algebraic calculator, not a hybrid like many calculators are. Andrew. |
Title: Re: awd calculator Post by Evgenii on Mar 1st, 2010, 7:10am Thanks, Andrew! |
