https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> about the ratio between bias circuit and main LNA circuit https://designers-guide.org/forum/YaBB.pl?num=1267593950 Message started by yixiusky on Mar 2nd, 2010, 9:25pm |
Title: about the ratio between bias circuit and main LNA circuit Post by yixiusky on Mar 2nd, 2010, 9:25pm Hello everyone: I would like to ask one question about the ratio between bias circuit and main circuit. I design the LNA. The bias reference current is 100uA, the main circuit current is 10mA. There are two choice to decide the ratio (1) 1:100 (2) 1:10: ~ 10:100 use two branch (a) Which one is better considering about mismatch,...? (b) And except simple current mirror, is there any method or reference talk about high ratio (1:100) current mirror? Thank you very much |
Title: Re: about the ratio between bias circuit and main LNA circuit Post by rfmagic on Mar 4th, 2010, 12:16am Hi yixiusky, In order to reduce mismatch you better use multiplicity of no more than 10. Further more, I use the last transistor of the current mirror (the one that's mirroring the LNA core) as RF transistor with same width and length as the LNA CS transistor ( but different multiplicity). this way you can ensure that the current mirror will follow the LNA CS transistor over PVT variations. Kob |
Title: Re: about the ratio between bias circuit and main LNA circuit Post by yixiusky on Mar 4th, 2010, 1:54am Hi Kob thank you very much , you helped me ^^ |
