https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> spectre pz analysis https://designers-guide.org/forum/YaBB.pl?num=1267816005 Message started by analogrf on Mar 5th, 2010, 11:06am |
Title: spectre pz analysis Post by analogrf on Mar 5th, 2010, 11:06am Hi all, Im using spectre's pole/zero analysis (using IC5141usr5). I find the pz analysis to be somewhat less fairly documented. Specifically, could someone tell if the pole zero plot obtained from pz analysis has any normalization factor on the real axis ? Also, what does 'constant factor' refer to ? Plz comment. Thanks |
