https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Ultrasim and Hiearchy Editor https://designers-guide.org/forum/YaBB.pl?num=1268068450 Message started by fz2101 on Mar 8th, 2010, 9:14am |
Title: Ultrasim and Hiearchy Editor Post by fz2101 on Mar 8th, 2010, 9:14am I'm simulating an oscillator circuit with Ultrasim, when I set what I believe to be the default accuracy in Analog Design Environment by going through Simulations -> Options -> Analog and change the Simulation Mode from the default Mixed Signal (MS, 5) to Analog (A,5), the oscillator oscillates. However, if I change the sim_mode and speed in Config to the same exact settings, i.e. "a" and "5", the oscillator does not oscillate. In fact, changing the sim_mode and speed in hiearchy editor seems to have no impact on the accuracy of the simulation. I used the Ultrasim template when I created the Config view. |
Title: Re: Ultrasim and Hiearchy Editor Post by Andrew Beckett on Mar 8th, 2010, 2:15pm Go to Simulation->Options->Analog in ADE (with UltraSim as the simulator) and check "Allow usim_opt on HED". Regards, Andrew. |
