https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> get spectre assert data from corners https://designers-guide.org/forum/YaBB.pl?num=1269625871 Message started by jshafer on Mar 26th, 2010, 10:51am |
Title: get spectre assert data from corners Post by jshafer on Mar 26th, 2010, 10:51am I'm trying to set some spectre assert checks, which I then want to run over corners using the corners tool. How can I get violation data, if any, from each corner run? |
Title: Re: get spectre assert data from corners Post by Andrew Beckett on Apr 7th, 2010, 6:23am See http://www.cadence.com/Community/forums/p/15284/61098.aspx#61098 Regards, Andrew. |
Title: Re: get spectre assert data from corners Post by Moshtaque on May 17th, 2010, 5:50pm Achim, Any news from cadence on this topic? ----------------------------------------------------- Hi, > Which version of MMSIM are you using? Device checking seems > to works by device model in MMSIM62 USR1. indeed > The menu includes > options for subcircuits so they are probably working also. unfourtunately not (neither subckt nor inline subckt in modelcard) As soon I get news from Cadence I will post here, Regards, Achim |
