https://designers-guide.org/forum/YaBB.pl Design >> High-Power Design >> Thermal shutdown...Buck converter... https://designers-guide.org/forum/YaBB.pl?num=1270708670 Message started by somisetty on Apr 7th, 2010, 11:37pm |
Title: Thermal shutdown...Buck converter... Post by somisetty on Apr 7th, 2010, 11:37pm Hi all... If the buck converter output is 1.2V and input varies from 2.7V to 3.3V and current is 500mA,and temp variation is -40 to 125.Buck is used in portable applications.Is it required to have thermal shutdown ? Thanks |
Title: Re: Thermal shutdown...Buck converter... Post by Sarig on Aug 20th, 2010, 1:39pm Yes. All converters has Thermal Shut Down. if you did mistake in design or from some reason load increase it can burn the chip. Pay attention from noise..... |
