https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Latch D->Latch T https://designers-guide.org/forum/YaBB.pl?num=1272225552 Message started by Daniel Minan on Apr 25th, 2010, 12:59pm |
Title: Latch D->Latch T Post by Daniel Minan on Apr 25th, 2010, 12:59pm I want to make a toggle latch from D latch using only data flow only: module latcht( input T, output Led ); wire d, c, qn; //1'b0; assign c = 1'b1; assign d = q^T; latchd U1( d, c, q, qn); endmodule module latchd( input D, input C, output Q, output Qn ); /*assign Q = ((C==1'b1&&D==1'b0)? 1'b0 :((C==1'b1 && D==1'b1)?1'b1: Q)); assign Qn = ~Q;*/ endmodule But when i tested the logic of the Led, it hold at z state all the time Sorry for my poor english |
Title: Re: Latch D->Latch T Post by boe on Apr 26th, 2010, 6:28am Daniel Minan, You need to force a defined initial state, e.g. by adding a reset. Without that your circuit is likely to remain in X (not Z) initial state. B O E |
