https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Common Source LNA stability https://designers-guide.org/forum/YaBB.pl?num=1272344339 Message started by unevb on Apr 26th, 2010, 9:58pm |
Title: Common Source LNA stability Post by unevb on Apr 26th, 2010, 9:58pm I am designing a single ended common source cascode LNA with inductor degeneration for a 5.5GHz receiver Is there any intuitive explanation about how the k-factor is dependent on the circuit paramaters (gm, vds or L,C values). When I burn a current 'I' in the LNA, k>1 across 10MHz to 10GHz, it is unconditionally stable. But if I reduce the current to 'I/10' , all other circuit performance are meeting spec, but the k drops below 1 for most the the frequency of interest. What is the relation between circuit parameters and k-factor or stability? If k is poor what can i improve in the circuit? |
Title: Re: Common Source LNA stability Post by pancho_hideboo on Apr 29th, 2010, 8:54am unevb wrote on Apr 26th, 2010, 9:58pm:
- Put shunt resistors for input or output or both which are ideally effective only for frequency range of poor K. - Resize transistor - Neutralization http://www.designers-guide.org/Forum/YaBB.pl?num=1264582305/5#5 |
Title: Re: Common Source LNA stability Post by unevb on May 5th, 2010, 10:46am Why is k-factor an issue at RF but not an issue at low frequency (audio-range) circuits? For a single device k<1 at low frequency (where we compute MSG) and after the threshold frequency k>1 and we care about MAG, so I would think k-factor to be important at all frequencies. If we are using a device which has k>1 at a mm-wave frequency eg. 60GHz then it is said to be "unconditionally stable" when used at 60GHz. Does this account for possible oscillations at lower frequencies when k becomes less than 1? Not many IEEE Papers on LNA circuits talk about the k-factor of the circuit. I have connected a 90nm device I am using , in common source configuration and plotted k-factor for different dimensions and it is never unconditionally stable over entire frequency range. Is there something that can be done at the architecture level to take care of this? I have not seen integrated circuits using input shunt resistors because of noise considerations. Thanks! |
Title: Re: Common Source LNA stability Post by pancho_hideboo on May 5th, 2010, 11:00am unevb wrote on May 5th, 2010, 10:46am:
K-factor is not used for PA design where large signal is concerned. I don't use K-factor even for LNA. See the followings. http://www.designers-guide.org/Forum/YaBB.pl?num=1218635777/5#5 http://www.designers-guide.org/Forum/YaBB.pl?num=1266403928/4#4 unevb wrote on May 5th, 2010, 10:46am:
Former is a resonator in many cases where impedance change drastically with frequency. Latter is a resistor in many cases where impedance almost does not change with frequency. pancho_hideboo wrote on Apr 29th, 2010, 8:54am:
We make bias circuitry and feed back network having frequency characteristics to prevent unpreferable oscillation in actual circuits. Shunt resistor which is effective for some frequency range is also this purpose. Cascode structure could be candidate for some case. BTW, have you been able to understand the following ? http://www.designers-guide.org/Forum/YaBB.pl?num=1272508752/3#3 MAG, MSG and U are not dependent on reference impedance even if S-parameter expressions are used. |
Title: Re: Common Source LNA stability Post by unevb on May 5th, 2010, 6:33pm Hi, Thanks for the reply. It is true, I am still at the very early stage in RF design and right now beginning to pick up "EDA-tool" play and learn from Technical papers. Thanks for your patience in answering my questions. Regards, |
Title: Re: Common Source LNA stability Post by RFICDUDE on May 7th, 2010, 7:32pm By "unpreferable oscillation" we mean that the real part of the impedance is "negative" over some frequency range which can only happen if there is positive feedback. You are wise to be concerned about low frequency stability when working with microwave and millimeter wave circuits. Often times the low frequency gain is so high (as compared to the desired high frequency gain) as to cause positive feedback at low frequencies. This can result in sinusoidal oscillations at HF, VHF or UHF frequencies, or (even worse) wideband chaotic instability. As Pancho suggested, low frequency terminations to prevent positive feedback at low frequencies is effective (a few books cover this). It can be more problematic in RC circuits. Bandpass tuned circuits may be less of a problem because the low frequency gain is naturally reduced by the reduced load impedance at low frequencies. |
