https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> MLIN simulation question in RFDE https://designers-guide.org/forum/YaBB.pl?num=1272383469 Message started by liletian on Apr 27th, 2010, 8:51am |
Title: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 8:51am Hi Guys I am simulating a filter using transmission line. I use MLIN for the transmission line in ADS. The software reports the following errors. Can anyone suggest how to fix it? It seems to complain I did not give the model for substrate which I specified as Msub1. Do I need to give a seperate substrate file? If so, can anyone give me a sample Msub1 file. I will greatly appreciate it. hpeesofsim (*) 350.500 Feb 18 2009 (built: 02/18/09 23:50:00) Copyright Agilent Technologies, 1989-2008. Warning detected by hpeesofsim during netlist flattening. Cannot find substrate `MSub1'. Error detected by hpeesofsim during netlist flattening. `I4': Expected a substrate model for parameter `Subst'. Flushing data (please wait) ... |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 27th, 2010, 9:29am I can't find out any design issue in your post. Your questions are no more than very easy issues regarding usage of very specific vendor's tool. liletian wrote on Apr 27th, 2010, 8:51am:
http://edocs.soco.agilent.com/display/ads2009/MSUB+%28Microstrip+Substrate%29 This is also available in "adsLib" of Agilent RFDE. |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 10:10am Hi pancho Thanks for your comments, I did find there is a component in adsLib called MSUB. However, can you specify how I can solve the problem? Any suggestions? Most of the adsLib components work fine so far except Mlin. I put a MSUB into the schematics and it still reported the same error. Thank you pancho_hideboo wrote on Apr 27th, 2010, 9:29am:
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 27th, 2010, 10:13am Show me schematic and netlist. I think you will fail in creating netlist because I think there are many mistakes in your schematics. |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 10:15am I attached the schematics, I did not find netlist file in the directory. |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 27th, 2010, 10:17am No. this is not substrate definition component. liletian wrote on Apr 27th, 2010, 10:15am:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1265391679 |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 10:19am could you please tell me how to define it? thanks pancho_hideboo wrote on Apr 27th, 2010, 10:17am:
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 27th, 2010, 10:23am Show me netlist. liletian wrote on Apr 27th, 2010, 10:19am:
In your schematic, there is no one. |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 10:28am pancho_hideboo wrote on Apr 27th, 2010, 10:23am:
I am sorry, it might be dummy question. But can you tell me how to place substrate definition component in schematic? The closest component I found in adsLib is MSUB. Please give details, thank you so much! |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 27th, 2010, 10:31am In your schematic, there is no "adsLib/MSUB". There are "MLIN", "TLIN", "Term", "analogLib/cap", "analogLib/res" and "analogLib/gnd". Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1265012932 From your all previous posts, I think you can't understand ADS and RFDE at all. |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 10:36am yes, I mixed the components from analogLib and adsLib. Thank you for your reply. I will have a look on the post. Why do you think I do not understand RFDE at all. I think RFDE is a software to use ADS simulator and library. And at the same, use cadence to layout. Are there more deep understanding on RFDE? Thank you again pancho_hideboo wrote on Apr 27th, 2010, 10:31am:
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 27th, 2010, 10:38am liletian wrote on Apr 27th, 2010, 10:36am:
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 10:44am It is might be true I did not know ADS too much. I modified the schematics, now it reported new errors. Here is the error. Any suggestions? hpeesofsim (*) 350.500 Feb 18 2009 (built: 02/18/09 23:50:00) Copyright Agilent Technologies, 1989-2008. Error detected by hpeesofsim during netlist parsing. ADS-syntax parser error in `input.ckt', line 6: syntax error Flushing data (please wait) ... hpeesofsim terminated due to an error. ds2psf_exe--ERROR: Cannot access file /home/hehe/simulation/test_TL_filter/ADSsim/schematic/netlist/data.ds. \nds2psf was unsuccessful. PSF files are not available for this simulation. pancho_hideboo wrote on Apr 27th, 2010, 10:38am:
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 27th, 2010, 10:48am There is a substrate definition component in this schematic(http://www.designers-guide.org/Forum/Attachments/Screenshot-3_001.png). liletian wrote on Apr 27th, 2010, 10:44am:
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 10:52am pancho_hideboo wrote on Apr 27th, 2010, 10:48am:
Now I understood there was no substrate in my previous post. I did not realize I need to put it in the schematics. First time to have this question. thank you! I did not find netlist file in my directory. I attached the totally directory file. thank you |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 27th, 2010, 11:00am pancho_hideboo wrote on Apr 27th, 2010, 10:58am:
thank you, I am looking forward to your reply. ;D |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 28th, 2010, 7:40am liletian wrote on Apr 27th, 2010, 11:00am:
hi pancho Did you have a look on the file? What is the problem? Thank you, B |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 28th, 2010, 8:16am liletian wrote on Apr 27th, 2010, 10:44am:
This is a syntax error in the above. See schematic for ADSsim in attached figure. On the other hand, you can enclose with double quotations if you use Agilent GoldenGate. (2) Callback skill code for netlisting of "adsLib/MSUB" is corrupted due to some reason. My RFDE is CDBA version of RFDE2008Update2. As far as CDBA version of RFDE2008Update2, callback skill code for netlisting of "MSUB" can't work. Try to use OpenAccess version, for exaple, OpenAccess version of RFDE2009 which is a final version of RFDE. (3) As workaround, don't place "adsLib/MSUB" in schematic. Instead include netlist scratch for "MSUB". It is easily available in ADS native environment. (4) Use Agilent GoldenGate instead of Agilent RFDE. |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 28th, 2010, 8:29am The followings are netlist sets for RFDE(ADSsim). "test_TL_filter.ads" Quote:
"msub1.ads" Quote:
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 28th, 2010, 8:36am The following is a netlist for Agilent GoldenGate. "test_TL_filter_GG.scs" Quote:
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 28th, 2010, 8:53am (3) As workaround, don't place "adsLib/MSUB" in schematic. Instead include netlist scratch for "MSUB". It is easily available in ADS native environment. How to do the netlist? It looks like RFDE does not generate the netlist for me. (4) Use Agilent GoldenGate. I rarely use GoldenGate and just give it a try. It reported the same errors. pancho_hideboo wrote on Apr 28th, 2010, 8:29am:
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 28th, 2010, 8:55am liletian wrote on Apr 28th, 2010, 8:53am:
Do you understand Cadence ADE ? About netlisting in ADS native environment, see http://www.designers-guide.org/Forum/YaBB.pl?num=1265191125/7#7 |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 28th, 2010, 8:59am how to use this file? can you please give me the totally directory of the RFDE ADS, so I can have a look? thanks pancho_hideboo wrote on Apr 28th, 2010, 8:29am:
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 28th, 2010, 9:00am Read all documenations of Agilent RFDE and Cadence ADE. liletian wrote on Apr 28th, 2010, 8:59am:
Again do you understand Cadence ADE ? |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 28th, 2010, 9:01am My understanding is Goldsden gate is only a simulator under RFDE. Again, I do not know much on Golden Gate. pancho_hideboo wrote on Apr 28th, 2010, 8:55am:
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 28th, 2010, 9:03am pancho_hideboo wrote on Apr 28th, 2010, 8:55am:
no, I do not know how to do it. can you tell me how to use it? Thanks |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 28th, 2010, 9:03am liletian wrote on Apr 28th, 2010, 9:01am:
http://www.designers-guide.org/Forum/YaBB.pl?num=1268404959/7#7 I'm not kind and patient enough for answering such too basic questions. |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 28th, 2010, 9:18am pancho_hideboo wrote on Apr 28th, 2010, 9:03am:
It is fine. I do not really need to know what golden Gate is? If you can tell me how to use the netlist you showed to me in ADS, I will greatly appreciate your help. Otherwise, thank you anyway for your help. |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 28th, 2010, 9:23am liletian wrote on Apr 28th, 2010, 9:18am:
Simply include "msub1.ads" just same as transistor model file including when you use Spectre in Cadence ADE. |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 28th, 2010, 9:49am pancho_hideboo wrote on Apr 28th, 2010, 9:23am:
whatever you say, thank you for your help. I finally got it to work. Thanks a lot! |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on Apr 29th, 2010, 1:37am liletian wrote on Apr 27th, 2010, 10:52am:
Your directory is no more than "cell view" of "test_TL_filter" in your "design library" of "test" not "total directory". Again do you understand directory structure of data created in Cadence DFII and Cadence ADE ? liletian wrote on Apr 28th, 2010, 8:59am:
Directory structure of RFDE is basically same as Cadence ADE. But directory structure of ADS project is different from RFDE. In ADS, project directory includes both design library and simulation data directory. On the other hand, in RFDE, project directory means simulation data directory which is different from design library. In RFDE, total directory means design library, custom reference library, simulation directory(project directory) and analysis state directory. "cell view" directory is never "total directory" in any meaning. In ADS, total directory mean one project directory if no other project directory is included. liletian wrote on Apr 27th, 2010, 10:36am:
Again surely read documentations of Cadence ADE and Agilent ADS and RFDE. |
Title: Re: MLIN simulation question in RFDE Post by liletian on Apr 29th, 2010, 8:38am pancho_hideboo wrote on Apr 29th, 2010, 1:37am:
Thank you! |
Title: Re: MLIN simulation question in RFDE Post by pancho_hideboo on May 6th, 2010, 2:42am The following is a netlist for Agilent GoldenGate simulator. As you can see, this netlist style is very different from Agilent ADSsim and Cadence Spectre. "SP.gg.expanded.gg" Quote:
