https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> comparator offset simulation https://designers-guide.org/forum/YaBB.pl?num=1273220335 Message started by VNF on May 7th, 2010, 1:18am |
Title: comparator offset simulation Post by VNF on May 7th, 2010, 1:18am Hi all, Does anybody know how to include transistor mismatch (also cap mismatch) into simulation in Cadence ADE? The transistor model I have from foundry does have something like " model nch bsim3v3 { 1: type=n minr=1e-60 lmin=1.2e-06 - dxl lmax=2.1e-05 wmin=1.2e-06 dxw wmax=1.01e-04 tnom=25 xl=3e-08 .... 2: type=n minr=1e-60 lmin=5e-07 - dxl lmax=1.2e-06 - dxl wmin=1.2e-06 - dxw wmax=1.01e-04 tnom=25 xl=3e-08 .... 3: type=n minr=1e-60 lmin=2.4e-07 lmax=5e-07 - dxl wmin=1.2e-06 dxw wmax=1.01e-04 tnom=25 xl=3e-08 .... 4: type=n minr=1e-60 lmin=1.2e-06 - dxl lmax=2.1e-05 wmin=6e-07 dxw wmax=1.2e-06 - dxw tnom=25 xl=3e-08 .... 5: type=n minr=1e-60 lmin=5e-07 - dxl lmax=1.2e-06 - dxl wmin=6e-07 - dxw wmax=1.2e-06 - dxw tnom=25 xl=3e-08 .... 6: type=n minr=1e-60 lmin=2.4e-07 lmax=5e-07 - dxl wmin=6e-07 dxw wmax=1.2e-06 - dxw tnom=25 xl=3e-08 .... .... 9: type=n minr=1e-60 lmin=2.4e-07 lmax=5e-07 - dxl wmin=3e-07 wmax=6e-07 - dxw tnom=25 xl=3e-08 + dxl flkmo .... } not sure if that is something related. Thanks! |
Title: Re: comparator offset simulation Post by pancho_hideboo on May 7th, 2010, 1:40am I can't find out any design issue in your post again. Your question is no more than easy issue related to specific vendor's simulator. VNF wrote on May 7th, 2010, 1:18am:
What simulator do you use ? I assume you use Cadence Spectre as simulator. The followings are descriptions for "binning". VNF wrote on May 7th, 2010, 1:18am:
Descriptions for mismatch are like following. Quote:
http://www.designers-guide.org/Forum/YaBB.pl?num=1074804759 http://www.designers-guide.org/Forum/YaBB.pl?num=1066706959 |
