https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> opamp's slewrate model in verilog-a https://designers-guide.org/forum/YaBB.pl?num=1273604822 Message started by samiran on May 11th, 2010, 12:07pm |
Title: opamp's slewrate model in verilog-a Post by samiran on May 11th, 2010, 12:07pm Hi all, I require a simplistic veriloga model of opamp in which I need to take care of opamp's output resistance, finite unity-gain-frequency, finite open-loop dc gain and slewrate. For this, I have written a veriloga code where I have considered the opamp as thevenin equivalent model i.e. a voltage-controlled-voltage-source (multiplication factor is the small-signal gain with single pole and finite dc gain defined inside the multiplication factor) and output resistance in series with the voltage source. Using this I am correctly recreating the small-signal behavior of the opamp. Now, the problem is, I need to incorporate the slew-rate (large-signal behavior) also into this. For this, I planned to put the condition like this: once the differential input is greater than a defined (can be controlled from outside) voltage level, output voltage will simply ramp-up with slewrate_plus / ramp-down with slewrate_minus. Is this correct, I mean does this define the slewing correctly? If so, how I can write the code in veriloga (I am new to veriloga and don't know many useful syntaxes). I am stumbling to write the ramping voltage. Please help me. Regards Samiran |
Title: Re: opamp's slewrate model in verilog-a Post by Marq Kole on May 12th, 2010, 7:12am Hi Samiran, There is a very useful built-in function to Verilog-A named slew(). You might want to check out the language reference manual for this. It takes two arguments: the expression whose the rate-of-change should be limited and the maximum allowed rate-of-change. It can take an optional third argument if the maximum negative rate-of-change has a different absolute value than the maximum positive rate-of-change. The second argument has to be positive, the optional third argument has to be negative. Sounds like what you need is: Code:
Of course, you probably have more elaborate code to handle the bandwidth and gain requirements, but if you fit in the slew() function slewrate should be taken care of properly. NB: slew() is an analog operator so generally it cannot appear inside an event, a loop, or a conditional. Cheers, Marq |
Title: Re: opamp's slewrate model in verilog-a Post by samiran on May 12th, 2010, 11:20pm Hi Marq, Thanks for the suggestion. My situation is to develop a model of opamp which includes the small-signal and large-signal (specifically slewing for large-step input/high frequency sinusoidal signal) behavior in one model. And also there will be an output buffer stage (mainly to take care of output resistance). But, I am stuck in implementing this as I am not really successfully putting the condition when to start slewing at the output instead of following the small-signal behavior. In my model, I have a gain stage modeled as VCCS (multiplication factor = gm, controlling voltage = input voltage), ro and a cap (CL) in parallel. This ro and CL are setting the dominant pole. And in the output stage its simply a VCVS (multiplication factor = 1, controlling voltage = voltage across the CL) with a series o/p resistance, Rout. What I am trying to do to implement slewing, is when input differential voltage is exceeding a certain voltage level, just setting a maximum constant current (Imax) through CL. But it is not really helping as I am unable to see any slewing for rail-to-rail input step. Do you have any idea, how this can be implemented? Thanks for you patience, with regards Samiran |
Title: Re: opamp's slewrate model in verilog-a Post by Ken Kundert on May 13th, 2010, 1:21am You could use the slew() function, as Marq suggested. -Ken |
Title: Re: opamp's slewrate model in verilog-a Post by Marq Kole on May 14th, 2010, 1:58am The slew() function is defined to operate correctly in both small-signal and large-signal analyses. You can apply this to your capacitance definition: Code:
Marq |
