https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Unable to change x-axis to one of the result waveform in Wavescan https://designers-guide.org/forum/YaBB.pl?num=1273723059 Message started by casual on May 12th, 2010, 8:57pm |
Title: Unable to change x-axis to one of the result waveform in Wavescan Post by casual on May 12th, 2010, 8:57pm Unable to change x-axis to one of the result waveform in Wavescan ic5141 The function is there, but it is not function. I found wavescan difficult to use compared to AWD. |
