Design >> High-Speed I/O Design >> Alexander PFD
https://designers-guide.org/forum/YaBB.pl?num=1274900372
Message started by neoflash on May 26th, 2010, 10:59am
Title: Alexander PFD
Post by neoflash on May 26th, 2010, 10:59am
Hi,
Almost all BB-PD used in CDR have no frequency detection capability.
What kind of behavior they will show if there is large frequency offset between data and local sampling clock?
Thanks,
Neo
Title: Re: Alexander PFD
Post by love_analog on May 31st, 2010, 6:56am
They will a parallel Frequency detector loop. Once the VCO is brought within range, you will switch over to the PD loop
Post by casual on Jun 2nd, 2010, 8:49pm
typically BB-PD has a narrow LPF bandwidth compared to linear PD
Post by casual on Jun 11th, 2010, 4:37am
Only feedforward CDR architecture (aka oversampling type) does not have frequency detector.
Post by KangSub on Jul 24th, 2010, 12:32am
hi,
followings are my opinion.
If there are large frequency offset between clock and data, BBPD will produce the random sequence of UP and DN outputs.
BBPD uses at least 3-sample in consecutive 2-UI for phase detection between clock and data and produces valid UP and DN according to the position of data transition.
on the other words, BBPD detects the position of data transition relative to that of clock, using consecutive 3-samples in 2-UI.
so, the frequency of clock and data have to be equal.
if there exist large frequency offset between data and clock, then, BBPD cannot sample 3-sample in consecutive 2-UI and cannot operate properly. �
in that case, the 3-samples have no information about the position of the data transition.
therefore, the output of the BBPD is not meaningful.
if the input data is PRBS, because the probability that sampled bit is 0 or 1 is always same, the UP and DN output of BBPD will also random sequence.
I don't think that Alexander BBPD  can detect any frequency information.
thanks,
- KangSub
Post by loose-electron on Aug 31st, 2010, 3:39pm
Um... this is covered in a dozen textbooks...
look into pull in range, and frequency acquisition vs phase acquisition.
Post by neoflash on Aug 31st, 2010, 4:31pm
Thanks for bring this reference source up.
Would you like to list 1-2 text books which you think are best in describing this issue?
Thanks.
loose-electron wrote on Aug 31st, 2010, 3:39pm:
