https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> temperature variation on AMS transient simulations https://designers-guide.org/forum/YaBB.pl?num=1275773203 Message started by thechopper on Jun 5th, 2010, 2:26pm |
Title: temperature variation on AMS transient simulations Post by thechopper on Jun 5th, 2010, 2:26pm Hi, Is there any way to run transient simulation in AMS where the temperature is slowly varied? Thanks for your comments. Tosei |
Title: Re: temperature variation on AMS transient simulations Post by boe on Jun 25th, 2010, 7:59am thechopper, Yes. Use something like (example from Cadence Spectre Circuit Simulator Reference): Code:
Hope this helps. BOE [Added:] Also this is from Spectre documentation, it also works with AMS. |
Title: Re: temperature variation on AMS transient simulations Post by ywguo on Jul 7th, 2010, 8:06am Hi Guys, It's really interesting to run a transient simulation while temperature varies slowly. However, how do I plot temperature variation vs. time in AWD or wavescan after the transient simulation finishes. Best Regards, Yawei |
Title: Re: temperature variation on AMS transient simulations Post by thechopper on Jul 15th, 2010, 7:02pm Thanks for your answer, boe. I knew in Spectre such simulation could be run, but I was not aware there was such an option in AMS environment. I'll try it out then. Best Tosei |
Title: Re: temperature variation on AMS transient simulations Post by boe on Sep 2nd, 2011, 5:50am ywguo wrote on Jul 7th, 2010, 8:06am:
Add the following line to your Spectre netlist: Code:
B O E |
