https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Is there any LDO with output voltage which is the same as reference? https://designers-guide.org/forum/YaBB.pl?num=1276073561 Message started by DP_Design on Jun 9th, 2010, 1:52am |
Title: Is there any LDO with output voltage which is the same as reference? Post by DP_Design on Jun 9th, 2010, 1:52am I am going to design LDO that supplys 1.2V stable output. I should use 1.2V reference voltage (BGR output) , which is the same voltage level of LDO output. Generally LDO output is divided by voltage divider consisted of resistors such as attached figure. Then Can I design the LDO without output divider? If R1->0, is it ok ? The alternative will be reference voltage division but i can't. |
Title: Re: Is there any LDO with output voltage which is the same as reference? Post by AnalogDE on Jun 9th, 2010, 11:23am Remove R1 and R2, take Out node to '-' input of opamp, then you just have a regular unity-gain buffer. |
Title: Re: Is there any LDO with output voltage which is the same as reference? Post by DP_Design on Jun 9th, 2010, 6:02pm If I Use Unity-gain buffer, then the Output Load transistor should be so big for current driving and then Op amp gain decreased. Is it Ok? LDO supplies over 100mA. AnalogDE wrote on Jun 9th, 2010, 11:23am:
Title: Re: Is there any LDO with output voltage which is the same as reference? Post by Mayank on Jun 9th, 2010, 9:31pm Quote:
If you take the OUT Node shown in Fig. back to Opamp I/p Terminal, then it is not a Unity Gain Config. Unity Gain Config will only be formed when you take the Opamp Output( i.e. gate of pMOS ) directly to it's i/p which doesnt make any sense for LDO. Taking OUT node back to opamp is Ok, & it's done sometimes. Just take care of the Big Bypass Cap you put at OUT Node doesnt affect the I/p Terminal of the Opamp. -- Mayank |
Title: Re: Is there any LDO with output voltage which is the same as reference? Post by DP_Design on Jun 10th, 2010, 12:54am Mayank wrote on Jun 9th, 2010, 9:31pm:
Thanks for your answer, Mayank. Do You mean "Taking Out node back to opamp" is "R1=0" ? And What will be the problem of opamp affected by cap? I can't get it.. |
Title: Re: Is there any LDO with output voltage which is the same as reference? Post by Mayank on Jun 10th, 2010, 9:02pm Quote:
Quote:
Just draw a small signal, solve KCLs & find out if you are not getting sm unnecessary Poles/Zeros -- just to be on a safer side. I dont think it should be a problem. -- Mayank. |
