https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Unexpected value of noise https://designers-guide.org/forum/YaBB.pl?num=1276201020 Message started by Vladislav D on Jun 10th, 2010, 12:16pm |
Title: Unexpected value of noise Post by Vladislav D on Jun 10th, 2010, 12:16pm We all know that the output noise of two resistor is 4*k*T*(R1 || R2). So, if both resistors have value of 50 Ohms, the output noise is 0.644nV/sqrt(Hz) (T=300K). If I simulate the circuit with two resistors and a voltage source I get the same result, however, if I substitute series resistor and voltage source with 50-Ohms port the output noise becomes 638nV/sqrt(Hz). I cannot find the explanation of this effect. Is this bug or I missed something? |
Title: Re: Unexpected value of noise Post by rfcooltools.com on Jun 10th, 2010, 8:56pm In Cadence the port has its own temperature. you may want to check what the default is set to. http://rfcooltools.com |
Title: Re: Unexpected value of noise Post by pancho_hideboo on Jun 12th, 2010, 6:52am I can't find out any design isuue in your question. Your question is no more than very easy issue of very specific vendor's simulator. What simulator do you use ? Vladislav D wrote on Jun 10th, 2010, 12:16pm:
Vout2=4*k*{R2/(R1+R2)}2*(R1*T1+R2*T2) Here R1 and T1 mean resistance and temperature of "port" respectively. If R1=R2=50, Vout2=50*k*(T1+T2) If T1=T2=300K, Vout=643.6[pVrms/sqrt(Hz)]. If T1=290K, T2=300K, Vout=638.2[pVrms/sqrt(Hz)]. See http://www.designers-guide.org/Forum/YaBB.pl?num=1192525133/10#10 The followings are general notes for you. - Always describe correct tool's name and vendor's name which you use as tool or simulator. - Don't do multiple posts which are same content. - Don't request source code or behavioral model without any efforts. - There are many simulators which have analyses called as PSS, PAC and Pnoise. - Describe in detail with using correct terminologies. - Warnigns are different from Errors. - ADS is not name of simulator. - There is no tool which name is Cadence. - Don't use Direct Plot of Cadence ADE blindly without knowing definition. - All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain. - Don't mix up Simulation with Post Processing. They are completely different phase. - MATLAB are different from Simulink. - Learn measurements using actual instruments. Not "EDA Tool Play |
Title: Re: Unexpected value of noise Post by pancho_hideboo on Jun 14th, 2010, 5:07am Agilent ADSsim treat temperature of port as analysis temperature, if it is not specified for all analyses except for SP-Analysis. In SP-Analysis of Agilent ADSsim, ADSsim treats port temperature as 290[K] even if you set any value as port temperature. Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1192525133/10#10 |
