https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> About monte carlo analysis https://designers-guide.org/forum/YaBB.pl?num=1277403352 Message started by wunderkind on Jun 24th, 2010, 11:15am |
Title: About monte carlo analysis Post by wunderkind on Jun 24th, 2010, 11:15am Hi all, I want to simulate the offset of a comparator and want to follow the way mentioned in this document: http://www.designers-guide.org/Analysis/comparator.pdf However, i don't know how to store the comparator's results into a file. I used the sampler found in designer's guide community, the link is: http://www.designers-guide.org/VerilogAMS/functional-blocks/smplr/sampler.vams But the problem is the content of the file will be replaced each time when one run of Monte Carlo analysis is finished so that I can only get the comparator's results for the last run of Monte Carlo analysis. I am just wondering how to store all comparator's results. Thank you |
Title: Re: About monte carlo analysis Post by pancho_hideboo on Jun 24th, 2010, 11:21am wunderkind wrote on Jun 24th, 2010, 11:15am:
What simulator do you use ? Show me netlist regarding analysis statements including monte carlo analysis. |
Title: Re: About monte carlo analysis Post by wunderkind on Jun 24th, 2010, 11:25am pancho_hideboo wrote on Jun 24th, 2010, 11:21am:
The simulator I use is Cadence Spectre |
Title: Re: About monte carlo analysis Post by pancho_hideboo on Jun 24th, 2010, 11:30am wunderkind wrote on Jun 24th, 2010, 11:25am:
Title: Re: About monte carlo analysis Post by wunderkind on Jun 24th, 2010, 1:46pm pancho_hideboo wrote on Jun 24th, 2010, 11:30am:
I have tried this, but it doesn't work |
Title: Re: About monte carlo analysis Post by pancho_hideboo on Jun 25th, 2010, 3:57am wunderkind wrote on Jun 24th, 2010, 1:46pm:
If you see result's data by using "Results Browser", there are many result's data. Do you use correct data which include all trial data in monte carlo ? |
Title: Re: About monte carlo analysis Post by wunderkind on Jun 28th, 2010, 4:03pm pancho_hideboo wrote on Jun 25th, 2010, 3:57am:
I have solved my problem by modifying the sentence of "file = $fopen(filename)" to "file = $fopen(filename, "a")" in the VerilogA for sampler. In such a way that I can get all Monte Carlo simulation results |
Title: Re: About monte carlo analysis Post by wunderkind on Jun 28th, 2010, 4:04pm pancho_hideboo wrote on Jun 25th, 2010, 3:57am:
Thank you very much, pancho_hideboo!! |
