https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> port probes: VerilogAMS vs VerilogA https://designers-guide.org/forum/YaBB.pl?num=1278417828 Message started by Misha on Jul 6th, 2010, 5:03am |
Title: port probes: VerilogAMS vs VerilogA Post by Misha on Jul 6th, 2010, 5:03am Hello, I have a VerilogA model that is working well in Spectre/APS. How I'm trying to simulate the design with Cadence AMS and get an error during the elaboration stage: Quote:
This a cell with some RLC components instantiated and in the code I'm trying to sens the current through one terminal. In the verilogA code this line uses the following syntax: B = I(mp,mp) / area; I tried naming this branch explicitly, but it does not help. Any idea how I can work around this? Thanks a lot in advance! Misha |
Title: Re: port probes: VerilogAMS vs VerilogA Post by Geoffrey_Coram on Jul 6th, 2010, 11:18am You probably have to go in and create an internal node module yourmod(mp, ...) inout mp, ...; electrical mp, ...; electrical mp_int; B = I(mp, mp_int) / area; and then connect all the internal hierarchy to mp_int instead of mp. |
Title: Re: port probes: VerilogAMS vs VerilogA Post by Misha on Jul 8th, 2010, 6:47am Thank you for the suggestion. It does work. But the problem turned out to be slightly different. In a different location of the code I had the same line with an addition originating from the ahdllib code that I used as a base for my model: Quote:
I guess it's a bug - the AMS simulator takes the first syntax but it actually is compliant with the second, same as the good old Spectre. I guess the Cadence's ahdllib was never QC'd with AMS simulator. Watch out for that VAMS_ENABLE macro :). Thanks anyway for the advice, Misha Thanks |
