https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> monte carlo/iip2/ocean https://designers-guide.org/forum/YaBB.pl?num=1279228504 Message started by salty on Jul 15th, 2010, 2:15pm |
Title: monte carlo/iip2/ocean Post by salty on Jul 15th, 2010, 2:15pm Simulator: spectre/ocean I have tried running qpss monte carlo sims. I would like to look at iip2 with mismatches. However, I can't quite figure out how to access the data in ocean. It is saving all the data from run to run, but how can I access the data from a specific run and calulate the iip2? |
Title: Re: monte carlo/iip2/ocean Post by pancho_hideboo on Jul 18th, 2010, 3:35am Use "openResults()" and "selectResult()". You have to set "savefamilyplots=yes" in montecarlo analysis statement. If you set this, data with "iteration" as independent variable are saved. Using "Results Browser", show me your data structures. |
Title: Re: monte carlo/iip2/ocean Post by salty on Jul 20th, 2010, 12:28pm analysis('pac ?name "pac" ?sweeptype "absolute" ?start "100.1M" ?stop "" ?maxsideband "3" ) analysis('pss ?name "pss" ?fund "100M" ?harms "5" ?errpreset "moderate" ) ;; Define Monte Carlo run monteCarlo( ?numIters "3" ?startIter "1" ?analysisVariation 'processAndMismatch ?sweptParam "None" ?sweptParamVals "27" ?saveData t ?nomRun "yes" ?append nil ?saveProcessParams t ) 0 -2.41910379 -0.3090832601 1.067701704 1.826176777 -0.1685257352 -0.4319062036 0.6163895371 0.06027179153 0.2159157092 0.4165311881 0.2370237454 -2.839598571 -0.06690625897 -0.1330360908 0.3674732837 0.1143423708 0.09194731515 0.5216838423 0.004004664022 -0.3139963948 -0.4351055748 -0.4674903287 -0.0892607145 0.0921801425 0.5002249218 0.1707400142 -0.05630772468 -1.281845534 -0.1718602428 0 1.140002663 0.2818457609 -0.3715128775 0.5170954804 -0.2651480862 0.5360666028 -0.1593445124 0.1371628181 1.005583024 -1.336634955 -0.6279941156 -0.5765937551 0.2608253194 -0.08196836804 0.1323324946 0.5308181952 0.1984952034 -0.4614614652 -0.07972303747 0.1472436608 -0.1563556275 -0.05822723993 0.5171307785 0.165831579 0.5877651979 0.411854726 0.3517394563 0.6228540472 0.5357093426 0 0.3688653866 0.6218775626 0.8805458147 -2.024383245 0.4532081174 0.6004590931 -0.05249134944 -0.09697661379 -0.296800175 -0.605173609 -1.309438672 0.4983259135 -0.3603986472 -0.2870969455 0.06142047725 0.06842420367 0.2189601318 0.04231622672 -0.1230972528 -0.1161719846 -0.08243078511 0.2980343352 -0.3683571826 -0.3880785018 0.07592628966 -0.2862654642 -0.002764599039 -0.4712424786 0.3462222281 |
Title: Re: monte carlo/iip2/ocean Post by salty on Jul 20th, 2010, 1:51pm It looks like I can select individual runs with selectResult( "mc1_pac-montecarlo" "1.0" ) selectResult( "mc1_pac-montecarlo" "2.0" ) etc. Is there a way to extract which process corner it was running? |
Title: Re: monte carlo/iip2/ocean Post by pancho_hideboo on Jul 21st, 2010, 9:51am salty wrote on Jul 20th, 2010, 1:51pm:
