https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> What does this mean in ADS --> S[1::2,1::2] https://designers-guide.org/forum/YaBB.pl?num=1279385505 Message started by DoYouLinux on Jul 17th, 2010, 9:51am |
Title: What does this mean in ADS --> S[1::2,1::2] Post by DoYouLinux on Jul 17th, 2010, 9:51am Hi everyone, I am trying to study about S parameters in ADS. I have seen from a file that in the "stoy" function, there is a variable defined in Mea Eqn as follows: Param_y = stoy(S[1::2,1::2]). In the schematic, there is an element called "S2P" driven by two ports Port 1 and Port 2. I guess that this is to transform S paramters to Y parameters. But, what does the syntax S[1::2, 1::2] mean ? Could someone explain to me please ? Thank you very much, DYL |
Title: Re: What does this mean in ADS --> S[1::2,1::2] Post by pancho_hideboo on Jul 18th, 2010, 3:12am See http://www.edaboard.com/ftopic400964.html |
Title: Re: What does this mean in ADS --> S[1::2,1::2] Post by RFICDUDE on Jul 18th, 2010, 4:02pm Pancho's link explains what the notation means, but if you want to know a simple way to use the stoy function just use (I think) stoy(S) or if you prefer or need z-parameters stoz(S) these functions will save the y and z parameter equivalent results for each s-parameter analysis simulation (all ports). The wildcard and sequence notation would be useful if you are only interested in doing a conversion for some select ports (I think). I use these functions when I'm interested in calculating the either the series or shunt effective lumped element equivalent resistance, capacitance and/or inductance over frequency. |
Title: Re: What does this mean in ADS --> S[1::2,1::2] Post by pancho_hideboo on Jul 26th, 2010, 4:57am "[]", "()" and "{}" have completely different meanings each other in Agilent ADS Post Processing Environment. S parameters are matrix, here you have to use "()" not "[]". Usually sequence operator, "::" is used for Array not Matrix. And if we use sequence operators for two-dimensional Array or Matrix, an applied indexing order such as "Row-Major" or "Colum-Major" is ambiguous. So I confirmed validity of sequence operator, "::" for two-dimensional Matrix. It seems an indexing is "Row-Major" as same as C-language. |
Title: Re: What does this mean in ADS --> S[1::2,1::2] Post by DoYouLinux on Jul 26th, 2010, 6:57am Hi RFDUDE, Thank you very much for your explanation. DYL |
Title: Re: What does this mean in ADS --> S[1::2,1::2] Post by DoYouLinux on Jul 26th, 2010, 7:10am Hi pancho_hideboo, Thank you very much for your answer. I actually used S(1::2,1::2) in my simulation, not S[1::2,1::2]. I have some further questions regarding your simulation: 1) How did you generate the input S parameters ( S(1,1) = 11+j0, S(1,2) = 12+j0, ...) ? 2) What is the main difference between using S(3::4,3::4) and S{{S33,S34},{S43,S44}} ? I think the result should be the same. Thank you in advance :) DYL |
Title: Re: What does this mean in ADS --> S[1::2,1::2] Post by DoYouLinux on Jul 26th, 2010, 7:23am Ah, my fault, I mean comparison between S(3::4,3::4) and {{S33,S34},{S43,S44}}, the result should be the same. DYL |
Title: Re: What does this mean in ADS --> S[1::2,1::2] Post by pancho_hideboo on Jul 26th, 2010, 8:24pm DoYouLinux wrote on Jul 26th, 2010, 7:10am:
http://edocs.soco.agilent.com/display/ads2009/S1P+Eqn+to+S6P+Eqn+%281-+to+6-Port+S-parameters%2C+Equation-Based%29 DoYouLinux wrote on Jul 26th, 2010, 7:10am:
Title: Re: What does this mean in ADS --> S[1::2,1::2] Post by DoYouLinux on Jul 27th, 2010, 6:29pm Hi pancho_hideboo, Thank you very much for your reply. This is my another new knowledge about ADS. DYL |
