https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Verilog-A code for charge pump https://designers-guide.org/forum/YaBB.pl?num=1280445279 Message started by vp1953 on Jul 29th, 2010, 4:14pm |
Title: Verilog-A code for charge pump Post by vp1953 on Jul 29th, 2010, 4:14pm I am looking for verilogA code to implement a charge pump (used in PLLs). The default code available in Cadence seems to be very unrealistic in that even when the output voltage is at ground or supply, current continues to be sunk/sourced resulting in substantial build of voltage. I did not find any code for a charge pump at the designers guide site (it has code for pretty much everything else). Thank you in advance! |
Title: Re: Verilog-A code for charge pump Post by Ken Kundert on Jul 31st, 2010, 10:38am Take a look at http://www.designers-guide.org/VerilogAMS/functional-blocks/pfd_cp/pfd_cp.va. I have updated the PFD/CP on this site to include an output clamp that limits the output voltage to the rails. -Ken |
Title: Re: Verilog-A code for charge pump Post by vp1953 on Aug 2nd, 2010, 11:25am Hi Ken, Thanks a million! It is greatly appreciated. |
