https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> higher charge pump current yields lower PD noise https://designers-guide.org/forum/YaBB.pl?num=1281948420 Message started by casual on Aug 16th, 2010, 1:46am |
Title: higher charge pump current yields lower PD noise Post by casual on Aug 16th, 2010, 1:46am "In general, a higher charge pump current yields lower phase detector noise." What is the reason behind? Is it because the R got to be reduced for large charge pump current in a given loop bandwidth? |
Title: Re: higher charge pump current yields lower PD noise Post by raja.cedt on Aug 16th, 2010, 3:57am hi, is your question correct. I think it should be like Higher current implies lower Noise contribution from charge pump., because transfer function from charge pump to PLL out is inversely proportional to charge pump current. Thanks, Rajasekhar. |
Title: Re: higher charge pump current yields lower PD noise Post by casual on Aug 16th, 2010, 4:29am it is quoted from Prof Micheal Perrott (MIT) document... still figuring out.. |
Title: Re: higher charge pump current yields lower PD noise Post by raja.cedt on Aug 16th, 2010, 5:30am hi, could you please share that doc..? Thanks, Rajasekhar. |
Title: Re: higher charge pump current yields lower PD noise Post by vp1953 on Aug 16th, 2010, 11:23am Higher charge pump current results in higher loop gain and larger loop bandwidth if the loop filter components are not changed. Larger loop bandwidth leads to greater suppression of close in phase noise. |
Title: Re: higher charge pump current yields lower PD noise Post by casual on Aug 16th, 2010, 10:38pm see attachment |
