https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Simulate steup and hold time of DFF https://designers-guide.org/forum/YaBB.pl?num=1283162711 Message started by ywguo on Aug 30th, 2010, 3:05am |
Title: Simulate steup and hold time of DFF Post by ywguo on Aug 30th, 2010, 3:05am Hi Guys, I want to get the setup and hold time of a DFF over all PVT corners. Is there any easy method in ADE using spectre simulator? Thanks Yawei |
Title: Re: Simulate steup and hold time of DFF Post by ywguo on Sep 20th, 2010, 2:42am Hi Guys, I recall that there is a tool named bi-section in HSPICE that is very useful to simulate setup/hold time of DFF. Is there any similar tool in spectre? Thanks Yawei |
Title: Re: Simulate steup and hold time of DFF Post by sheldon on Sep 20th, 2010, 4:12am Yawei, Look at SpectreMDL, it should be able to do what you want. Best Regards, Sheldon |
