Design >> RF Design >> Quality factor of resonant circuit and Quality factor of inductor both are same?
https://designers-guide.org/forum/YaBB.pl?num=1284542165
Message started by suryakumari on Sep 15th, 2010, 1:16am
Title: Quality factor of resonant circuit and Quality factor of inductor both are same?
Post by suryakumari on Sep 15th, 2010, 1:16am
What is the difference between quality factor of the resonant circuit and quality factor of the inductor??
both are same?? can anyone tel for both parallel and series resonant circuit
Thanku
surya
Title: Re: Quality factor of resonant circuit and Quality factor of inductor both are same?
Post by Manish Dudhat on Sep 15th, 2010, 3:33am
Dear friend,
i think as per the formula of Q-factor thats for RLC circuit is ,Q = R (sqrt{{C}/{L}),, so it must e different, as in the case of inductor circuit having or not having (only parasitic capacitor).
i hope so, that will sound ok...
Regards,
Manish
Post by anil reddy on Sep 15th, 2010, 5:08am
hello..
the quality factor of the circuit (either series RLC or parallel RLC resonant circuit) indicates how fast the circuit is dissipating the energy through that explicit resistor (R). this is called the Q of the circuit..
on the other hand, �Q of a component comes from when you take parasitic resistance associated with that component...
thank you...
Post by tkhan on Sep 15th, 2010, 5:23am
Read http://rfic.eecs.berkeley.edu/142/pdf/lect5.pdf
Post by Frank Wiedmann on Sep 15th, 2010, 6:23am
For the different definitions of the quality factor and their meaning, see http://scholar.google.com/scholar?cluster=3790526195310866712&hl=en&as_sdt=2000.
Post by rfmems on Sep 15th, 2010, 6:30am
In my opinion, Q of RLC is only meaningful at its resonance frequency,
Q of an inductor or a cap is meaningful at all frequcies.
Post by pancho_hideboo on Sep 15th, 2010, 9:19am
See http://www.designers-guide.org/Forum/YaBB.pl?num=1278414763/14#14
Post by surya on Sep 29th, 2010, 2:06am
Thank U :)
Post by raja.cedt on Sep 29th, 2010, 3:46am
hi Surya ,
while talking about parallel resonator most of the time general assumption is inductor is the only non-ideal thing and rest all are ideal (no parasitic), but if you capacitor also non-ideal then you can say
1/Qt=1/QL+1/QC. where Ql is inductor quality factor and Qc is varactor quality factor.
Thanks.
Post by surya on Oct 1st, 2010, 2:32am
K i got it...
Thank u
Post by Ken Kundert on Oct 1st, 2010, 8:53pm
Saam,
   People are making an effort on your behalf. Please show them the respect they deserve by using full words rather than IM shorthand.
-Ken
Post by saam on Oct 2nd, 2010, 3:37am
I am really sorry....
    Thank you for your advice and i feel very happy for getting not only knowledge also suggestions for the new people like me to this forum.
   Thank you :)
