https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> how to flush out the buffer in verilog A? https://designers-guide.org/forum/YaBB.pl?num=1285607944 Message started by Irvin73 on Sep 27th, 2010, 10:19am |
Title: how to flush out the buffer in verilog A? Post by Irvin73 on Sep 27th, 2010, 10:19am Hi, I run relatively long transient spectre simulation with some verilog-A block which on each "cycle" of simulation should print data to the log file. Like in following example - Code:
The problem is that the log file updated only after the simulation completes, and I want to do monitoring of the log during the simulation. I think there is some way to control the flushing of the buffer, can anyone help with this? Tnanks. |
Title: Re: how to flush out the buffer in verilog A? Post by Geoffrey_Coram on Sep 28th, 2010, 6:04am Try $fflush(logFile); |
Title: Re: how to flush out the buffer in verilog A? Post by Irvin73 on Sep 28th, 2010, 6:36am It works, many thanks! Interesting thing - this function is not documented, at least I can't find it in "Cadence®Verilog®-A Language Reference" pdf (2006). Is my documentation obsolete? :) Thanks again for quick and useful response. |
Title: Re: how to flush out the buffer in verilog A? Post by Geoffrey_Coram on Sep 29th, 2010, 8:45am I found this in the IEEE 1800-2009 standard. I know some vendors implement features like this in their (digital) Verilog simulators, and then I guess it's an easy port to add to their analog or AMS simulators. |
