https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> parameter sweep / operating point https://designers-guide.org/forum/YaBB.pl?num=1285824473 Message started by ontheverge on Sep 29th, 2010, 10:27pm |
Title: parameter sweep / operating point Post by ontheverge on Sep 29th, 2010, 10:27pm Hi, I'm trying to sweep the width of a MOSFET and check the corresponding changes of a few node voltages and seems the command SWEEP can not be used with .op My question is, is it possible to do so without any .DC .AC or transient analysis? thanks, Stephen |
Title: Re: parameter sweep / operating point Post by ontheverge on Sep 29th, 2010, 10:33pm Sorry forgot to mention, I was using Avant! star HSpice |
Title: Re: parameter sweep / operating point Post by ontheverge on Sep 30th, 2010, 12:36pm pancho_hideboo wrote on Sep 30th, 2010, 5:08am:
.alter gives you only one set of new simulation data, while putting a bunch of .alter command will surely do, just wonder if easier ways exist |
Title: Re: parameter sweep / operating point Post by Geoffrey_Coram on Oct 4th, 2010, 2:14pm ontheverge wrote on Sep 30th, 2010, 12:36pm:
Why not use .dc to sweep the parameter?? |
