https://designers-guide.org/forum/YaBB.pl Simulators >> Logic Simulators >> verilog - print to file a 3d arrayHi, How do i export to file a 3d array in ver https://designers-guide.org/forum/YaBB.pl?num=1286184117 Message started by uzicohen10 on Oct 4th, 2010, 2:21am |
Title: verilog - print to file a 3d arrayHi, How do i export to file a 3d array in ver Post by uzicohen10 on Oct 4th, 2010, 2:21am Hi, How do i export to file a 3d array in verilog? usually i use writememh with 2d bit array example: Declaration: reg [7:0] arr [31:0]; write to file: $writememh("PrintedArr.txt",arr); Tnx in advance. |
