https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> global nodes in verilog-ams https://designers-guide.org/forum/YaBB.pl?num=1286976374 Message started by Luke Whitaker on Oct 13th, 2010, 6:26am |
Title: global nodes in verilog-ams Post by Luke Whitaker on Oct 13th, 2010, 6:26am Hello design community, The cell I'm trying to make a verilog-ams module for has several global power nodes. There is a power on reset in the module that needs to monitor a global power signal. The top level schematic declares this node with an exclaimation point, vdd! for example. The global signal's ramp rate is controlled by a vpwl, so the global cannot be a static real value. How do I access these global power nodes from my verilog-ams module? In general I don't like global variables (other than ground '0'), but the designer I'm working with does and wants to keep them in his design. Thanks for your help. Best regards, Luke |
Title: Re: global nodes in verilog-ams Post by Marq Kole on Nov 17th, 2010, 7:01am The global node has to be defined somewhere. One way to do this is to create a separate module at top-level - say "module globals ();" - that contains these top-level nodes and then reference them from the AMS by using their hierarchical names: Code:
You might run into trouble using the escaped identifier - in that case make a connection from vdd! to a global node with a name that doesn't require an escaped identifier. Cheers, Marq |
