https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Maximize ICMR https://designers-guide.org/forum/YaBB.pl?num=1287498970 Message started by extremis on Oct 19th, 2010, 7:36am |
Title: Maximize ICMR Post by extremis on Oct 19th, 2010, 7:36am I am designing an OPAMP with 0.6μm technology (Vtp=-0.9V, Vtn=0.7V) and i have a specification of ICMR=0.5-2.5V to meet. The power supply is 3V (single). I have considered the clasic 2 stage OPAMP with Miller compensation, the cascode and the folded cascode OPAMP, but i don't see how the ICMR requirement could be satisfied. The folded cascode OPAMP seems to meet either the upper or the lower specification depending whether it has a NMOS or PMOS input differential pair, but not both. Could anyone suggest a simple topology that could meet the ICMR specification? Thanks in advance. |
Title: Re: Maximize ICMR Post by AnalogDE on Oct 19th, 2010, 9:29am I think you need an input stage that contains both N and P diff pairs. Search for "rail-to-rail" OTAs/op-amps. |
Title: Re: Maximize ICMR Post by extremis on Oct 22nd, 2010, 2:56am Thanks for the advice. I have found some rail to rail topologies, but they are too complicated and might even not satisfy other requirements. I was wondering if there is some kind of trick to increase ICMR using a simple topology. |
Title: Re: Maximize ICMR Post by Dan Clement on Oct 23rd, 2010, 1:03pm Level shifters... Like resistor dividers or source followers. Rail to rail amps can be a real pain because now you have two input stages to lead to distortion, offset, noise, etc... Good luck. |
Title: Re: Maximize ICMR Post by extremis on Nov 23rd, 2010, 8:14am Dan, i tried both approaches: source followers work just fine until Vcm~0.8V but after that the gain is lowered and resistor dividers seem to degrade performance, especially slew rate. I guess it has something to do with input capacitances but still i cannot find any way around it. |
