https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> stability issue..... https://designers-guide.org/forum/YaBB.pl?num=1288185023 Message started by saam on Oct 27th, 2010, 6:10am |
Title: stability issue..... Post by saam on Oct 27th, 2010, 6:10am Capacitor C also serves for ensuring the stability of the circuit. Since the open-loop transfer function has two poles very close to each other, introducing a dominant pole at node 2 improves stability. Can anyone explain why? (i am attaching the circuit) Thank U saam |
Title: Re: stability issue..... Post by jayce3390 on Dec 2nd, 2010, 8:07am This is real part of poles which is important, not the fact that they are close to each other... You need poles with a negative real part to ensure stability. |
Title: Re: stability issue..... Post by Frank Wiedmann on Dec 3rd, 2010, 12:58am See http://web.engr.oregonstate.edu/~karti/ece422/lec11_16_10.pdf, especially the slides entitled "Adding a Dominant Pole". |
