https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> diode https://designers-guide.org/forum/YaBB.pl?num=1288765220 Message started by SAM_K on Nov 2nd, 2010, 11:20pm |
Title: diode Post by SAM_K on Nov 2nd, 2010, 11:20pm how do i increse the scalability(varying w,l etc.) of the four regions of a diode if im doing an empirical fit with decent accuracy in VeriolgA. |
Title: Re: diode Post by Geoffrey_Coram on Nov 4th, 2010, 5:50am SAM_K wrote on Nov 2nd, 2010, 11:20pm:
I'm not quite sure how Verilog-A is involved here -- do you have a compact model description of a diode written in Verilog-A? If you're trying to fit four regions, then you'd better have equations for the four different regions. Diode models built into commercial simulators typically have a couple saturation currents: forward, reverse/breakdown, tunneling. |
Title: Re: diode Post by jerome_ams on Nov 8th, 2010, 7:30am yes I ll go in this direction as well: => I would take this descripion as a starting point: http://www.designers-guide.org/VerilogAMS/semiconductors/diode/diode.va , and implement all the features I d need using equations derived from the physics to have a parametrizable model. Cheers, Jerome |
