https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> 2V in 0.18um technology https://designers-guide.org/forum/YaBB.pl?num=1290144428 Message started by casual on Nov 18th, 2010, 9:27pm |
Title: 2V in 0.18um technology Post by casual on Nov 18th, 2010, 9:27pm I use 2V power supply instead of 1.8V in 0.18um technology. I rise the power supply from 1.8V to 2V because my circuits (thin gate) need more headroom and bandwidth to run at much higher speed (doing research). Is it common to do so? |
Title: Re: 2V in 0.18um technology Post by raja.cedt on Nov 18th, 2010, 10:53pm no its not acceptable because it will stress the devices but you can check with the foundry Thanks. |
Title: Re: 2V in 0.18um technology Post by casual on Nov 18th, 2010, 11:00pm the design is a CML logic where all the transistors do not experience more than 1V in their Vds and Vgs. |
Title: Re: 2V in 0.18um technology Post by ipmsn5 on Nov 25th, 2010, 12:04am yes, we used it in DDR2 system 0.18um TSMC process to get high speed frequency. |
