https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> difference of HB and PSS/HB in ADE https://designers-guide.org/forum/YaBB.pl?num=1290725131 Message started by Aigneryu on Nov 25th, 2010, 2:45pm |
Title: difference of HB and PSS/HB in ADE Post by Aigneryu on Nov 25th, 2010, 2:45pm Dear All, In some MMSIM versions, I can see a separate HB analysis option in the ADE analyses menu while the PSS>HB option is still available. The setup parameters in HB option menu are slightly different from those in PSS/HB (PSS and then select HB engine). What will be the difference if I invoke HB through these two different options? |
Title: Re: difference of HB and PSS/HB in ADE Post by Andrew Beckett on Jan 2nd, 2011, 10:56pm The main reason for adding a separate hb analysis was to appeal to users more familiar with other harmonic balance simulators, to give a single analysis setup regardless of whether there is one tone or multiple tones, and also to avoid cluttering the analysis with parameters which are only used in the Shooting Newton method. The underlying engine is the same though. There are some capabilities which are supported in the separate hb analysis which are not in the Harmonic Balance mode of pss/qpss though:
Regards, Andrew. |
Title: Re: difference of HB and PSS/HB in ADE Post by Aigneryu on Jan 14th, 2011, 3:36pm Thanks Andrew, I have been waiting for your answer for quite some time. By the way, you mentioned that in HB analysis setup, we can perform a semi-autonomous HB analysis. Does that mean I can use it to simulate the injection pulling of an oscillator (not injection-locked)? |
Title: Re: difference of HB and PSS/HB in ADE Post by Andrew Beckett on Jan 15th, 2011, 11:03am Sorry nobody responded sooner - I was away from this forum for a number of months. Yes, I believe it should be possible to simulate the effects of injection pulling with semi-autonomous. I've certainly used it to look at the effects on noise by having an interferer, so I don't see why this should be any different (I've just not tried it personally so far). Regards, Andrew. |
